Hi, Is this considered Series Parallel with AA Batteries
dl324
Joined Mar 30, 2015
18,523
Welcome to AAC!
You have 2 batteries in parallel in series with the 3rd. There's no valid reason for doing that.
Jon Chandler
Joined Jun 12, 2008
1,659
Not gonna happen with 3 AA batteries.
A 3 watt LED with Vf = 3.3v will draw nearly 1 amp. 6 such LEDs will draw almost 6 amps.
Here's the discharge curve for a alkaline AA battery. What's the service life at 6 amps?
dl324
Joined Mar 30, 2015
18,523
The LEDs will be each connected in parallel
Each with their own current limiting resistor?
The nominal voltage of a Li-ion battery is 4.2V. You can run them down to around 3.5V. Typical capacity is about 2Ah for 18650's. If you go that route, be mindful of counterfeits.
Juvan Estev
Joined Jun 6, 2024
6
Thank You, Sir
It is for a rectangle box light fixture I am making
BobTPH
Joined Jun 5, 2013
11,678
You cannot get 3.3V form two AA in series. The best configuration of 3AA batteries is three in series giving you 4.5V.
And, as others have pointed out, you will mot get 6A from that for more than a few minutes, if ever.
How long do the batteries need to last?
