Hi, Is this Circuit Correct
WBahn
Joined Mar 31, 2012
33,122
Without the discharge pin connected, how is the timing capacitor supposed to get discharged?
Look at the 555 datasheet and try to use a proper circuit.
Also, consider whether expecting a 555 output to directly drive a low-impedance speaker is realistic. I haven't done much with speakers, so maybe it is reasonable to get some decent sound directly.
WBahn
Joined Mar 31, 2012
33,122
by the Output pin.
Ah, yes. Old eyes playing tricks on me. I thought I was seeing something that wasn't there. Thanks.
But that would seem to underscore the concern about whether the output can really pull the low-impedance load low enough.
AlbertHall
Joined Jun 4, 2014
12,652
The NE555 can source or sink 200mA. 200mA would be 320mW into 8Ω so it should produce audible sound.
But it MUST be an NE555, not a CMOS version with different letters at the start.
boostbuck
Joined Oct 5, 2017
1,060
A 47k timing resistor and 10uf capacitor gives a run frequency in the order of 10Hz, which is to low to hear in the speaker and too fast to see the led flashing.
With a 47k resistor, 10n cap should generate an audible tone, or a 100uf cap should blink the light visibly.
