Hey guys.any solutions for the questions below
Marc Sugrue
Joined Jan 19, 2018
222
As a clue try redrawing the circuits, Maybe consider simplifying the networks. How do you simplify Series and Parallel resistor networks - what is their equivalent circuits? Once you know the resistances demonstrate your knowledge of Ohms Law to find Currents.
MrAl
Joined Jun 17, 2014
13,859
Yes there should be solutions, but read the first sticky thread in this section of the forum. This is homework HELP not homework done for you. What that manes here is that you have to show at least some work, some attempt at solving at least one of the problems. That helps everybody here figure out where you are in your scholastic work so the proper solution method can be shown to you if needed.
Take care,
MrAL
