help with using functions to calculate projectile height on impact
Killerbee65
Joined May 15, 2017
256
Hello all!
I recently got an assignment from my pressor that ask me to Write a program that computes the duration of a projectile’s flight and its height above the ground when it reaches the target.
He gave us the following equations to work with:
a. time = distance/ velocity x cos(0)
b. height = velocity x sin(0) x time - (g x time^2)/2
distance, velocity, and angle are all inputs from the user and g is a gravitational consistency of 32.17
Course : Computer science and programming
Section : 07
Date : 09 / 23 / 2020
Purpose:
Analysis/ Data:
1. inputs: angle, distance, velocity (float)
2. output: time in seconds, height (float)
3. equations
Typical-
input:
expected output:
Results:
Boundry-
input:
expected output:
results:
Extreme-
input:
expected output:
results:
#include <iostream>
#include <cmath>
using namespace std;
float velocity, target_distance, angle;
float grav_const = 32.17;
float inPuts( ) {
cout << "please enter the velocity of the projectile: ";
cin >> velocity;
cout << "it's distance: ";
cin >> target_distance;
cout << "The angle: ";
cin >> angle;
return velocity, target_distance, angle;
float time ( ) {
inPuts( );
return target_distance/ velocity * cos(angle);//equation for time
float height() {
inPuts();
time();
float height1 = velocity * sin(angle) * time() - (grav_const * (time() * time())) / 2;//equation for height
return height1;
int main() {
cout << time() << endl << height();
I'm using a different ide so I'm not sure if I copied and pasted correctly.
I keep getting consistent numbers when I input numbers yet they are wrong (ex: 1, 1, 1 for the inputs ->.54 for output or time). Also, the code consistently repeats 5 times yet I have no loops. I was tight for time so I only tested to see if the computer ran through each function.
RBR1317
Joined Nov 13, 2010
715
If the numbers are wrong it may be because the equation for time needs some additional parentheses. Also, I am unfamiliar with this style of programming (not being a programmer); what language is it?
SamR
Joined Mar 19, 2019
5,539
32.17? Flying pigs? What are the units? I prefer 9.8 m/s^2 for gravity... And even when going up, it is falling down. Just a couple of hints...
Killerbee65
Joined May 15, 2017
256
I know what you mean with the 32.17, I prefer 9.8m/s^2 but it is what my professor wants. But could you elaborate on your hint? I have an idea but I'm not sure my professor wants it to be too complicated.
SamR
Joined Mar 19, 2019
5,539
Dealing with projectiles, as soon as they leave the fixed mounted position gravity acts upon them determining their flight path. Hence even though they may be increasing in altitude they are also falling @ gravitational acceleration. Or else what goes up would not come down. Therefore they do not travel in a straight line. The US Navy spent billions of dollars calculating trajectories. In classical physics such things as air density changes with elevation, barometric pressures resultant frictional forces on projectile trajectories, diameter of projectile, shape of projectile, subsonic and supersonic frontal waves, etc. are ignored but were computed in the Naval calculations. Hence their need for computers such as ENIAC et al. It is much more complicated than gravity, angle, and velocity.
Wolframore
Joined Jan 21, 2019
2,619
32.17 ft/sec^2 is a conversion factor for gravity in English units. Useful if your bullets flight is measured in yards and feet.
drc_567
Joined Dec 29, 2008
1,156
g is plain gravitational acceleration ... \(32 ft/sec^2\).
\(g_c \) is the conversion factor between pound mass ... \(lb_m\), and pound force .. \(lb_f\) and is equal to \(32 [lb_m *ft]/[lb_f *sec^2]\)
The conversion factor is necessary when checking units in various formulae involving \(lb_m\).
Killerbee65
Joined May 15, 2017
256
Sorry for the late reply, been busy with school work, My professor has since uploaded the solution but thanks everyone for your help.
