Help with trouble shooting sit stand desk control box PCB
Qasimhmdn
Joined May 30, 2023
Hello guys, so i have an electric sit stand desk and it stopped working a while ago, i opened up the control box model TC15L from TI motion, and saw the IC in the pictures was fried so much so that it was impossible to read the part number off of the IC. Upon touching this IC, it blew away like dust. Now my question is that is it possible to know what IC was that or no?
Irving
Joined Jan 30, 2016
5,154
Sadly, unless you can find a picture from another TC15-PCB1 its impossible to say. TiMotion manufacture the controller, they might sell you another controller, but I doubt they'll be helpful enough to give chip info or sell a replacement board. You might find one on eBay?
[edit] a little more research found this picture... which clarifies the purpose of the chip which is under L1 in the top RH corner... its a switch-mode power supply running from the 32v supply from the other module and supplies 5v to the rest of the circuitry. For it to fry like that suggests a catastrophic failure and its likely that 32v found its way to the 5v rail. Which in turn suggests the rest of the controller and probably the handset/display are toast as well.Even if the chip could be replaced its unlikely the fault would be fixed.
Qasimhmdn
Joined May 30, 2023
Thanks heaps
hiphopity
Joined Aug 11, 2025
Does anyone know the resistance on the covered resistor next to the transformer (big yellow box)? I had a surge that fried that resistor and arced to the metal plate, there is no other visible damage other than soot around it. The surge cracked the thing in half and burnt most of the distinguishable marks on it to be able to tell what it's resistance is. I'm hoping to replace that part and hopefully have a working standing desk again. As far as I can tell it needs to be rated 5-10W but I'm getting wildly different answers as to what resistance to use because from the marks I can make out the resistance could be anywhere between 10 ohms, 110, and 1010 ohms. I'd like to eer on the safe side and get an exact match.
Did you eventually get this fixed ?
