Help with relay
Absconditus
Joined Aug 23, 2021
5
Hi guys,
Computer newbie here so hi to everyone.
I've built myself a power supply from an old PC PSU so I have 3 output voltages which all works great. I'm just learning about relays and other components. My question is regarding the following relay circuits diagram.
I understand that when I put 12 volts on the coil a magnetic field is generated and operates the switch, which is normally open.
However I have for pins on the bottom and two on the top, the to bring for the secondary circuit. And two of the bottom four for the coil. But I can't figure out what the other two pins do on the bottom ?
Could someone explain in simple terms.
30,661
Appears to be a N/C contact pont WRT the common relay terminal?
Strange to have contacts on the top and bottom?
Post a pic of the relay.
30,661
It would seems to me that the bottom connection shown that also connects to one of the large contacts may be for circuit monitoring only?
What function does it perform in the circuit?
Absconditus
Joined Aug 23, 2021
5
No idea it was out of an old microwave I just salvaged some parts to learn about them.
