Help with propeller clock math
cmartinez
Joined Jan 17, 2007
8,853
Note that the listing say 300 RPM max, that is only 5 revolutions per second. I think that might be too slow for persistance of vision to create a whole picutre.
Good point ... maybe he could experiment with a hand held drill to which a piece of tape is attached, and see at what minimum RPMs the effect works best?
spinnaker
Joined Oct 29, 2009
7,830
Yep saw that but I am betting it can be pushed well beyond that. It might not last for years but who cares. :)
My limiting factor of concern is transmitting of the data via the slip ring.
I will probably be putting the pic on the spinning board. I was going to add bluetooth anyway. I properly designed program will let me play with the various timing parameters and could also provide useful feedback (RPM speed etc). Debugging will be a challenge getting the Pickit# connected to a spinning board. ;)
spinnaker
Joined Oct 29, 2009
7,830
I already have a motor all set up waiting to be tested but the drill is a great idea. The experiment will be two fold.
1. Test if slip ring holds up to higher RPM
2. Test if I reliably transmit to my shift register via a slip ring. I already have the shift register bread boarded and working. Just need to add the slip ring into the mix.
spinnaker
Joined Oct 29, 2009
7,830
LOL the motor I selected does not even have enough torque to overcome the resitance of the slip ring. ;) Funny it does not feel all that tight when I spin it by hand.
I tried the drill idea. Holds up just fine to 2000 RPM. Well over the 300 RPM limit as I expected.
spinnaker
Joined Oct 29, 2009
7,830
Why not buy a larger motor? Or use the motor of a cheap-o air fan?
The problem with a fan would be getting an axle mounted dead center. Then how to mount it? I suppose it could be glued?
I have a much larger motor that would be over kill but no coupler for it.
But I still don't know if I can successfully reliably transmit serial data via the slip ring. I guess I could test that with the drill pretty easily.
