Assuming Beta=100, I did some calculations but ended up using some trial and error with the emitter resistor (Re) to get the current right. With respect to the schematic I posted on page 2: Re=120k, R1=510k, R2=360k. From the simulation I just found that Beta is actually 200.
*(For all of these results I'm using a sine wave source @ 40mVpp, 1000Hz)
- Vout in diff.-mode = 6.6 Vpp
- Vout in comm.-mode = .0001 Vpp (this wave is centered around 4.73V)
- Ic1,2 = 14.64uA
- Io = 29.41uA (current source collector current)
There's no clipping either!
One thing I'm concerned about is the common-mode voltage level (i guess it's the DC level?), although it's peak to peak voltage is very small. Is this a problem?
I'm using LT Spice to simulate. For testing the common-mode I make the two sinewave sources the same polarity and for diff-mode, opposite polarity (like what I'll be doing when testing the actual circuit).
