Help with microphone.
abdulk79
Joined Jan 8, 2016
13
I have VW microphone which works with stock audio unit but doesnt work with my Android based audio unit.
MIC which came with Android head unit is working properly.
I have noticed that Android head unit MIC is a 2 pin MIC which is directly connected to mono pin and stock MIC has some circuit and is 3 pin MIC.
Is there anyway i can bypass the circuit and use stock MIC.
I have attached photos of stock MIC.
Please help.
Thanks.
Dodgydave
Joined Jun 22, 2012
9,644
The 3 pin microphone has transistors on the pcb for amplified output, and will have a voltage supply to it.
So your option is to connect the screen coax cable directly to the microphone pins.
abdulk79
Joined Jan 8, 2016
13
Which pin? MIC is 3 PIN and there are 2 wires in cable.
Ground is connected to 1 PIN and I tried connecting other wire to remaining PINs in different combination but it didn't work.
Jonlate
Joined Dec 21, 2017
97
Usually on a 2 wire setup you would have pin 1 & 3 connected together as your shield and black or ground and negative, and pin 2 for your red or your live wire.
Have you tried not using the ground and wire into positive and negative only?
