Thanks Dana I have looked at that diagram but its for a difference Rev board and is not complete.There seems to be a schematic over here -
https://forum.allaboutcircuits.com/attachments/mc2100_rev_engrd-pdf.149329/
Regards, Dana.
Already posted, it an earlier version.Hello,
I found a reversed engineered schematic of the MC2100.
I hope this will help a bit.
I do not know if it will completely fit.
Thanks Max,I have the earlier non-SMT versions, but the C17 exist and is in the same place, 100μf.
The motor wasn't getting any voltage. It turned out the 360ohm resistor off the TD3052 random switching triac was open circuit.What was the reason for the removal in the first place, suspect a problem?
I assume you mean the incline motor, not the track motor? , as the latter is PWM operated.The motor wasn't getting any voltage. It turned out the 360ohm resistor off the TD3052 random switching triac was open circuit.
Regarding on R16 and R21 I couldn't find the value of it, will u provide a shmatic but it's not for the same type of the board, can I have the value of those comments coz it burn out while testing the treadmill.Hoping someone could help me with the values for the eight 16V capacitors and the four resistors?
I did make a list of the components while disassembling the board but now I can't find where I saved the list
Thank you in advance.
