How much how far how fast would you like to count then which direction would you like to count you want to count down you want to count up you want to count sideways? 400 series of sea moss Oops,CMOS Complimentary Metal Oxide semiconductor as opposed to TTL Transistor Transistor Logic got you decoded outputs more likely you going to be using BCD binary coded decimal to increment the count then the decoded seven segment LED display driver display's the number. You mean something like that?Asynchronous counter,
Its for a project in school and i dont really understand it. I the counter to print the first 10 values(0-9).In the schematic i was given i need to make the counter and connect to a oscillatorHello therewelcome to AAC.
What do you mean "print"?the counter to print the first 10 values(0-9)
show. On a seven segment display i need my circuit to show the first 10 values(0-9)What do you mean "print"?
this the sketch i got from my teacher the 'numerator' means counter in my countryhi razvan,
Do you have a rough sketch showing how you think it could be done, we can then help you.
E
Are you allowed to use a BCD to seven segment decoder? Or are you supposed to design your own?with decoded outputs
What is a DC display?displayed using a DC display
What type of flip flop are you allowed to use?Only 4000 series circuits will be used.
For school work, you need to show your best effort so we can see where you're having problems and can offer guidance.Someone has some ideeas ?
This is the full translated version from my school project.Are you allowed to use a BCD to seven segment decoder? Or are you supposed to design your own?
It would be helpful if you posted the complete (translated) instructions. Are you actually building the circuit? Or are you simulating?
The text is ambiguous. What you have learned to date in your classes will likely dictate your approach and the components you would use.Asynchronous decadic counter, made with dedicated flip-flops, with decoded outputs and displayed using a DC display. Only 4000 series circuits will be used.
Ai rezolvat cu circuitul? Si eu am aceasi tema la un proiect.Asynchronous counter, made with dedicated flip-flops, with decoded outputs and displayed using a DC display. Only 4000 series circuits will be used.
| J | Looking for Audio Circuit Board Source Help | General Electronics Chat | 2 | |
Asynchronous mod13 down counter help | Homework Help | 1 | |
| D | in need of help with an Asynchronous Data Transmitter | Homework Help | 1 | |
| T | help with asynchronous counter | Homework Help | 1 | |
| M | help me pleas "asynchronous binary up counter " | Homework Help | 6 |
