Help with 240V 120mA fan connection to mains
ericgibbs
Joined Jan 29, 2010
21,577
hi M,
The datasheet states spade terminals, usually spade sockets are fixed to the end of the mains wires and then pushed on the spade terminals.
You can solder the wires directly to the spade terminals, if you don't have the mating sockets.
Fuse it at approx 3Amp.
E
Mooafwsa
Joined Aug 17, 2020
13
hi M,
E
So if I strip a say PC power supply cable then connect to positive and negative of the spade sockets, then connect to mains this should work??
ericgibbs
Joined Jan 29, 2010
21,577
hi,
The 240V AC mains supply and fan are Line and Neutral , not + and -.
Connection:
Wall mains socket >> fused mains plug >> twin mains wire >> Fan spade terminals.
E
Note: ONLY twin mains wire between Mains Plug and Fan, nothing else in between.
Mooafwsa
Joined Aug 17, 2020
13
hi,
Connection:
E
So I would stripe the twin mains wire off a mains plug and solder line and neutral to the fan spade terminals?
