Help using DPDT relays to activate DC motor on - trigger
Status
Not open for further replies.
mach828
Joined Dec 20, 2014
1
I'm trying to use ground triggers from an alarm system to lock and unlock the doors on a system from the drivers side door switch. Which has both motor wires grounded when the button is not pressed, and transfers power to one wire when unlock button is pressed and the opposite when locked button is pressed. Right now my door switch functions normally.
I'm using two DPDT switches, the green filled terminals from one relay will connect when the alarm ground on that relay is activated, providing 12v while the other side remains grounded. But I'm blowing my inline fuse from my 12v power switch when I initiate the alarm ground. So, my circuit is wrong and I don't know if it would even lock/unlock the doors or not. Any insight would be greatly appreciated.
Essentially I'm just trying to duplicate what the OEM switch is doing but using a negative trigger from the alarm.
http://i182.photobucket.com/albums/x307/ama828ehs/DPDTalarmwiring_zpsf331b174.jpg
bertus
Joined Apr 5, 2008
23,001
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics.
The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
There will be enough sites where automotive questions can be discussed :
Member selected automotive forums
Status
