Help understanding the PWM signal at a brushed motor
Ian0
Joined Aug 7, 2020
13,317
Ifthe low side emitter is not connected to the motor power return, at least not according to the data sheet. Pin #8 is shown as a "ground" while the motor current is shown using pins #1 and #15. Further on, in the applications segment, the connections are confusing.
Pins 1 and 15 allow the insertion of a current sense resistor between the bridge negative and ground. If the TS is running it without pins 1,4 and 15 connected, I'm not sure how it can be working - the current must be finding a way through the substrate diode
