help understanding circuit
mat350z1
Joined Dec 4, 2014
7
Hello everyone.
Im a noob and i want to learn
I want to build my own efficient fly back driver
I do have a decent understanding of electronic circuits. But i need help with this one. I want to design and build my own zero volt switching driver for a fly back i have. It has an exposed ferrite core that i can manage to wrap seven turns of 14 gauge wire around. My question is how do i calculate the the current draw of the primary side of the transformer at a frequency of around 30khz? at 12 volts. can i use standard inductor calculations or does the core of the transformer or the secondary side of the transformer have an impact on these calculations. What are the effects on the circuit when the transformer is running in its resonant frequency. Afterwords how do i figure out what the best FETs are to use. I have looked at a number of examples of the ZVS circuits, but i do not understand why certain components are placed, where they are in the circuit. I have an example attached.
In the picture i don't understand to purpose of the inductor feeding the primary side of the transformer. Nor do i understand the purpose of the capacitor across the primary. Is it for frequency limitation? And what purpose do the two 400 volt diodes serve?
Thanks. sorry for so many questions. i just want to learn all this.
cmartinez
Joined Jan 17, 2007
8,762
Simply because that takes the fun out of it, i want to build one of my own design.
Then you're in the right place... though I myself won't be able to teach you much... this is borderline outside my area of expertise. But I'm willing to participate anyway I can...
ScottWang
Joined Aug 23, 2012
7,501
I'm not sure how long the higher voltage as 35V or 40V will keeping in the input, if Vin=40V, how is the watts of current limiting resistor:
Vin=40V-12V=28V
I_470=28V/470Ω=59.6mA.
W_470=28V*59.6mA=1.67W
If using the least rating of power dissipation as 3 time, then the w=1.67W*3=5W.
To me I might using 5 times to do the calculation.
mat350z1
Joined Dec 4, 2014
7
Thanks cmartinez. I appreciate that. And not quite this is only suppose to drive the fly back transformer to generate the high voltage spark
Scott. As far as i understand that 470 ohm resistor only goes to the gate of the mosfet which are turned on by a minuscule amount of power. so i dont think that the 2 watt resistor is underrated even at 40 volts, i could be wrong though.
cmartinez
Joined Jan 17, 2007
8,762
I've already looked up some other circuits for what you want to accomplish... The one that has drawn my attention the most is this one, since it seems that it can be calibrated depending on your original signal strength.
18,104
I've seen plasma speaker demonstrations often at college engineering open houses. Science fair type stuff. There should be a lot of info out there but I haven't looked.
Like you, I don't fully follow the circuit you posted.
ScottWang
Joined Aug 23, 2012
7,501
I just according to the voltages to calculates the power dissipation, no matter the resistor where to located on, when you completed the circuit then you can using your finger to feel it or using thermometer.
mat350z1
Joined Dec 4, 2014
7
Thanks Scott you are right
And thanks for the help cmartinez.
so no one really knows whats going on in the circuit i posted.? okay i guess im going to do some more digging.
