help to replace tacho generator
MaxHeadRoom
Joined Jul 18, 2013
30,808
I would guess that if the OP does not want to try a simple/cheap DC motor solution, he may balk at a replacement drive.
It would also help to know the exact kind of machinery it is on, servo positioning? CNC? Open loop, simple velocity?
Max.
strantor
Joined Oct 3, 2010
6,875
Max.
Maybe his issue isn't with cost. Maybe he just doesn't trust your advice. We may never know; unless I missed something, he's just ignored your every post thus far.
MaxHeadRoom
Joined Jul 18, 2013
30,808
I see you appear to be determined to use a device in the $100's of dollars in place of exploring a precision miniature DC motor such as Pittman or Maxon for a tach for < $50.00 on ebay.
That unit BTW maxes out at 10vdc, so if your motor is 2k to 3k rpm it will not meet the required limit of 10v/1krpm.
Max.
strantor
Joined Oct 3, 2010
6,875
Exactly! There are more examples like this one. I have used the one he linked and it's a good product, but like all its competitors, it only deals in today's typical signals; 0-10V, 1-5V, 4-20mA, etc. Trying to find a product that actually simulates a DC tach, like the kind OP has (or worse, those that can put out upwards of 300V), well it's maddening. There's no such thing. And there should be, IMO.
MaxHeadRoom
Joined Jul 18, 2013
30,808
In the past there may have been a need, or now for legacy drive systems, but in the world of DC Servo's now, DC tach's are not used (torque mode now) , plus most servo's have gone to BLDC/AC so IF a application is needed for some kind of open velocity loop, the commutation pulses are used for tach purpose.
At least that has been my experience so far.
Max.
strantor
Joined Oct 3, 2010
6,875
In the past there may have been a need, or now for legacy drive systems, but in the world of DC Servo's now, DC tach's are not used (torque mode now) , plus most servo's have gone to BLDC/AC so IF a application is needed for some kind of open velocity loop, the commutation pulses are used.
Max.
Right. Sorry, that was an unannounced continuation of my previous rambling in this thread about replacing legacy tachs on legacy machines with legacy drives, where the signal from the faulty tach goes to multiple destinations - those destinations sometimes being legacy purpose-made analog control cards for which there is no replacement. I've been in the situation before that I had to purchase a several thousand dollar special dual tach because without it, a complete retrofit of all machine controls would be required. In that unique situation (and I've been there more than once), such a niche high voltage signal conditioner would have been ideal. But there's no such thing. And I had plans to make one, but didn't follow through.
ss.achary
Joined Oct 27, 2015
28
Max sir my senior had tried with miniature dc motor... But it failed... If they fix miniature dc motor.. The drive runs it and shows tacho alarm..
larrydd
Joined Nov 4, 2015
Having worked - many years ago - as a senior service technician for a company that manufactured DC and AC drives, I recall that quite a few DC drives we sold used back EMF feedback (i.e. the DC output) to stabilize the speed. Admittedly this gives a lower performance than a tachometer, but in many applications was quite adequate. Perhaps this would work in this application. I've long discarded the diagrams, but perhaps someone else could help - if it would be useful to do so.
