help to correct code speed meter , RPM and distance -pic 16f877 ( UART)
jayanthd
Joined Jul 4, 2015
945
Don't use different arrays[] for getting the string results. I see that when your code is compiled we get
"IRP bit must be set manually for indirect access to 'show_distance' variable frecuenciametr0.c"
RAM is very less in PIC16F877A and so just use one char array[] like char msg[17] to get the string values for printing.
What is not working in your code ?
jayanthd
Joined Jul 4, 2015
945
Try this code. Tell me what happens.
Is this the display you are using ?
https://robu.in/product/nextion-nx3...0-jcdiK_Cy3Hxk2vlzBz36VvD7iNOkXUaAkylEALw_wcB
Code:
unsigned long counter = 0;
unsigned long period = 0;
unsigned int currentCaptureTime = 0;
unsigned int previousCaptureTime = 0;
unsigned long rpm = 0;
unsigned int rps = 0;
double distance = 0.0;
double speedKmsPerHour = 0.0;
double speedMilesPerHour = 0.0;
char msg[17];
void interrupt() {
     if((TMR1IE_bit) && (TMR1IF_bit)) {
         TMR1IF_bit = 0;
         ++counter;
     if((CCP1IE_bit) && (CCP1IF_bit)) {
         CCP1IF_bit = 0;
         currentCaptureTime = CCPR1;
         period = counter * (unsigned long)0xFFFF - (unsigned long)previousCaptureTime + (unsigned long)currentCaptureTime;
         rpm = (unsigned long)(60.0e6 / (double)period);
         rps = rpm / 60;
         distance = distance + (double)rps * 34.55751915e-5;
         speedKmsPerHour = (double)rps * 34.55751915e-5 * 2.77778e-4;
         speedMilesPerHour = (double)rps * 34.55751915e-5 * 6.21371e-6 * 2.77778e-4;
         previousCaptureTime = currentCaptureTime;
         counter = 0;
// copy const to ram string
char *CopyConst2Ram(char *dest, const char *src) {
    char *d;
    d = dest;
    for(;*dest++ = *src++;);
    return d;
void Delay_XSec(unsigned char sec) {
     while(sec) {
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        sec--;
void nextionWrite255() {
    asm clrwdt
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    asm clrwdt
void main() {
    asm clrwdt
    OPTION_REG = 0x8F;
    TRISC = 0x84;
    PORTC = 0x00;
    UART1_Init(115200);
    Delay_ms(100);
    T1CON = 0x01;
    TMR1H = 0x00;
    TMR1L = 0x00;
    TMR1IE_bit = 1;
    CCP1CON = 0x04;
    CCP1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    while(1) {
        asm clrwdt
        sprinti(msg,"n0.val=%d",rpm/1000);
        UART1_Write_Text(msg);
        nextionWrite255();
        sprinti(msg,"n1.val=%d",distance * 1e4);
        nextionWrite255();
        sprinti(msg,"n2.val=%d",speedKmsPerHour * 1e6);
        nextionWrite255();
        sprinti(msg,"n3.val=%d",speedMilesPerHour * 1e6);
        nextionWrite255();
        Delay_XSec(1);
jayanthd
Joined Jul 4, 2015
945
Did you check the Lcd I mentioned ? Is your Lcd part name same as th eone I showed ?
NX3224T024-Generic 2.4″ TFT ?
Sorry, test this new code. The sprinti() cannot format floating point numbers. PIC16F877A doesn't support sprintf() in mikroC.
Code:
char msg[32];
char txt[32];
void interrupt() {
         TMR1IF_bit = 0;
         ++counter;
         CCP1IF_bit = 0;
         rps = rpm / 60;
         counter = 0;
    char *d;
    d = dest;
    return d;
     while(sec) {
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        sec--;
    asm clrwdt
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    asm clrwdt
void main() {
    asm clrwdt
    OPTION_REG = 0x8F;
    TRISC = 0x84;
    PORTC = 0x00;
    UART1_Init(115200);
    Delay_ms(100);
    T1CON = 0x01;
    TMR1H = 0x00;
    TMR1L = 0x00;
    TMR1IF_bit = 0;
    TMR1IE_bit = 1;
    CCP1CON = 0x04;
    CCP1IF_bit = 0;
    CCP1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    while(1) {
        asm clrwdt
        nextionWrite255();
        strcpy(msg,"n1.val=");
        FloatToStr(distance,txt);
        strcat(msg,txt);
        nextionWrite255();
        strcpy(msg,"n2.val=");
        FloatToStr(speedKmsPerHour,txt);
        strcat(msg,txt);
        nextionWrite255();
        strcpy(msg,"n3.val=");
        FloatToStr(speedMilesPerHour,txt);
        strcat(msg,txt);
        nextionWrite255();
        Delay_XSec(1);
Try this code also.
Code:
char msg[32];
char txt[32];
void interrupt() {
         TMR1IF_bit = 0;
         ++counter;
         CCP1IF_bit = 0;
         rps = rpm / 60;
         distance = distance + (double)rpm * 34.55751915e-5;
         counter = 0;
    char *d;
    d = dest;
    return d;
     while(sec) {
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        sec--;
    asm clrwdt
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    asm clrwdt
void main() {
    asm clrwdt
    OPTION_REG = 0x8F;
    TRISC = 0x84;
    PORTC = 0x00;
    UART1_Init(115200);
    Delay_ms(100);
    T1CON = 0x01;
    TMR1H = 0x00;
    TMR1L = 0x00;
    TMR1IF_bit = 0;
    TMR1IE_bit = 1;
    CCP1CON = 0x04;
    CCP1IF_bit = 0;
    CCP1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    while(1) {
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        strcat(msg," kms");
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        strcat(msg," kms/hr");
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        strcat(msg," miles/hr");
        asm clrwdt
        nextionWrite255();
        Delay_XSec(1);
jayanthd
Joined Jul 4, 2015
945
Do you want distance in cm or kms ?
Here is distance test code. It should display distance in cms. Test and reply.
C:
char msg[32];
char txt[32];
void interrupt() {
         TMR1IF_bit = 0;
         ++counter;
         CCP1IF_bit = 0;
         rps = rpm / 60;
         distance = distance + (double)rpm * 0.9599;
         //speedKmsPerHour = (double)rps * 34.55751915e-5 * 2.77778e-4;
         //speedMilesPerHour = (double)rps * 34.55751915e-5 * 6.21371e-6 * 2.77778e-4;
         speedKmsPerHour = (double)rps * 99.9532e-9;
         speedMilesPerHour = (double)rps * 596.474e-15;
         counter = 0;
    char *d;
    d = dest;
    return d;
     while(sec) {
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        sec--;
    asm clrwdt
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    asm clrwdt
void main() {
    asm clrwdt
    OPTION_REG = 0x8F;
    TRISC = 0x84;
    PORTC = 0x00;
    UART1_Init(115200);
    Delay_ms(100);
    T1CON = 0x01;
    TMR1H = 0x00;
    TMR1L = 0x00;
    TMR1IF_bit = 0;
    TMR1IE_bit = 1;
    CCP1CON = 0x04;
    CCP1IF_bit = 0;
    CCP1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    while(1) {
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        strcat(msg," cms");
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        asm clrwdt
        nextionWrite255();
        Delay_XSec(1);
jayanthd
Joined Jul 4, 2015
945
Test this new code. I am sure the issues related to rpm and distance are fixed in this.
You calculation is wrong.
Your Fosc is 20 MHz and you had used 1:1 prescalar. I have changed prescalar to 1:8 and so,
Fosc / 4 = 20 MHz / 4 = 5000000
1/5000000 = 0.0000002
Prescalar = 1:8 = 8
0.0000002 * 8 = 0.0000016 = 1.6us
60/1.6us = 37.5e6
Calculation shown in book page no. 136 is
10 MHz / 4 = 2500000
1/2500000 = 0.0000004
Prescalar = 1:2 = 2
0.0000004 * 2 = 0.8us
60/0.8us = 75e6
rpm = 37.5e6 * period / 36 is correct
In book code they use 1 pulse per revolution and you have 36 pulse per revolution.
So, 37.5/36 = 1.042
So, code should be
Code:
char msg[32];
char txt[32];
void interrupt() {
         TMR1IF_bit = 0;
         ++counter;
         CCP1IF_bit = 0;
         rpm = (unsigned long)(37.5e6 / (double)period / 36.0);
         rps = rpm / 60;
         distance = distance + (double)rps * 34.55752e-5;  //rps * 2 * pi *r = rps * 2 * pi * d / 2 = rps * pi * d cms
        //1cm = 1e-5 km
         counter = 0;
    char *d;
    d = dest;
    return d;
     while(sec) {
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        sec--;
    asm clrwdt
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    //UART1_Write_Text("\r\n");
    asm clrwdt
void main() {
    asm clrwdt
    OPTION_REG = 0x8F;
    TRISC = 0x84;
    PORTC = 0x00;
    UART1_Init(115200);
    Delay_ms(100);
    T1CON = 0x31;
    TMR1H = 0x00;
    TMR1L = 0x00;
    TMR1IF_bit = 0;
    TMR1IE_bit = 1;
    CCP1CON = 0x04;
    CCP1IF_bit = 0;
    CCP1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    while(1) {
        asm clrwdt
        //strcpy(msg,"rps = ");
        strcpy(msg,"n0.val=");
        LongToStr(rps,txt);
        asm clrwdt
        strcat(msg,txt);
        asm clrwdt
        nextionWrite255();
        //strcpy(msg,"rpm = ");
        LongToStr(rpm,txt);
        asm clrwdt
        strcat(msg,txt);
        asm clrwdt
        nextionWrite255();
        //strcpy(msg,"distance = ");
        asm clrwdt
        strcat(msg,txt);
        strcat(msg," kms");
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        asm clrwdt
        nextionWrite255();
        Delay_XSec(1);
360 pulses/sec = 10 revolutions (36 pulses = 1 revolution)
10 revolutions/sec (Proteus Simulation)
rps = 10 for input 360 Hz
rpm = rps * 60 = 10 * 60 = 600
MCU_1548107851
Joined Jan 21, 2019
30
yes i need in km
and last code you send to me contain many comment //
which one i have to keep it and which delete
i think you try code with protues similation
but with nextion lcd will not work
because you use string converter
see your last code in attachment
also which mhz cristal you recommend me to use 4 mhz or 20 mhz
to give exact time
jayanthd
Joined Jul 4, 2015
945
Try this for nextion.
It displays rpm and distance as of now.
I am getting IRP bit must be set manually to access txt[]. This happens with mikroC and PIC16Fs that have very low RAM.
Solution = use PIC18F and problem will be solved.
PIC18F mikroc library supports sprinti() and also sprintf() for floating point values.
I am using 20 MHz crystal and 1:8 Prescalar for Timer1.
This is the new nextion code. LongtoStr() and IntToStr() does the same thing that sprinti() does. Don't change anything. Just test this code.
Code:
#define PULSE_PER_REVOLUTION       36.0
#define FOSC                 20000000.0
#define PRESCALAR                   8.0
#define PI                          3.14159265
#define DIA                        11.0
#define cm_to_km                    1.0e-5
#define sec_to_hr                   2.77778e-4
#define km_to_miles                 6.21371e-6
char msg[32];
char txt[32];
void interrupt() {
         TMR1IF_bit = 0;
         ++counter;
         CCP1IF_bit = 0;
         rpm = (unsigned long)((60.0 / ((1.0 / (FOSC / 4.0) * PRESCALAR))) / (double)period / PULSE_PER_REVOLUTION);
         rps = rpm / 60;
         distance = distance + (double)rps * PI * DIA * cm_to_km;  //rps * 2 * pi *r = rps * 2 * pi * d / 2 = rps * pi * d cms
        //1cm = 1e-5 km
         speedKmsPerHour = (double)rps * PI * DIA * cm_to_km * sec_to_hr;
         speedMilesPerHour = (double)rps * PI * DIA * cm_to_km * km_to_miles * sec_to_hr;
         counter = 0;
    char *d;
    d = dest;
    return d;
     while(sec) {
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        asm clrwdt
        Delay_ms(200);
        sec--;
    asm clrwdt
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    asm clrwdt
void main() {
    asm clrwdt
    OPTION_REG = 0x8F;
    TRISC = 0x84;
    PORTC = 0x00;
    UART1_Init(115200);
    Delay_ms(100);
    T1CON = 0x31;
    TMR1H = 0x00;
    TMR1L = 0x00;
    TMR1IF_bit = 0;
    TMR1IE_bit = 1;
    CCP1CON = 0x04;
    CCP1IF_bit = 0;
    CCP1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    while(1) {
        asm clrwdt
        LongToStr(rps,txt);
        asm clrwdt
        strcat(msg,txt);
        asm clrwdt
        nextionWrite255();
        LongToStr(rpm,txt);
        asm clrwdt
        strcat(msg,txt);
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        strcat(msg," kms");
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        asm clrwdt
        nextionWrite255();
        asm clrwdt
        strcat(msg,txt);
        asm clrwdt
        nextionWrite255();
        Delay_XSec(1);
Code:
#define FOSC                  20.0e6
#define DIA                   11.0
jayanthd
Joined Jul 4, 2015
945
Just use this code. See if nextion display works.
Code:
#define FOSC                  20.0e6
#define DIA                   11.0
char msg[32];
char txt[32];
void interrupt() {
         TMR1IF_bit = 0;
         ++counter;
         CCP1IF_bit = 0;
         rps = rpm / 60;
        //1cm = 1e-5 km
         counter = 0;
    char *d;
    d = dest;
    return d;
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    UART1_Write(0xFF);
void main() {
    TRISC = 0x84;
    PORTC = 0x00;
    UART1_Init(115200);
    Delay_ms(100);
    T1CON = 0x31;
    TMR1H = 0x00;
    TMR1L = 0x00;
    TMR1IF_bit = 0;
    TMR1IE_bit = 1;
    CCP1CON = 0x04;
    CCP1IF_bit = 0;
    CCP1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    while(1) {
        LongToStr(rpm,txt);
        strcat(msg,txt);
        nextionWrite255();
        strcat(msg,txt);
        //strcat(msg," kms");
        nextionWrite255();
        strcat(msg,txt);
        //strcat(msg," kms/hr");
        nextionWrite255();
        strcat(msg,txt);
        //strcat(msg," miles/hr");
        nextionWrite255();
        Delay_ms(1000);
jayanthd
Joined Jul 4, 2015
945
New code, test it.
cm to miles conversion was wrong. I have fixed it.
Code:
#define FOSC                  20.0e6
#define DIA                   11.0
#define cm_to_miles            6.21371e-6
char msg[32];
char txt[32];
void interrupt() {
         TMR1IF_bit = 0;
         ++counter;
         CCP1IF_bit = 0;
         rps = rpm / 60;
        //1cm = 1e-5 km
         speedMilesPerHour = (double)rps * PI * DIA * cm_to_miles * sec_to_hr;
         counter = 0;
    char *d;
    d = dest;
    return d;
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    UART1_Write(0xFF);
void main() {
    TRISC = 0x84;
    PORTC = 0x00;
    UART1_Init(115200);
    Delay_ms(100);
    T1CON = 0x31;
    TMR1H = 0x00;
    TMR1L = 0x00;
    TMR1IF_bit = 0;
    TMR1IE_bit = 1;
    CCP1CON = 0x04;
    CCP1IF_bit = 0;
    CCP1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    while(1) {
        LongToStr(rpm,txt);
        strcat(msg,txt);
        nextionWrite255();
        strcat(msg,txt);
        nextionWrite255();
        strcat(msg,txt);
        nextionWrite255();
        strcat(msg,txt);
        nextionWrite255();
        Delay_ms(1000);
jayanthd
Joined Jul 4, 2015
945
See if this gives all the values on nextion display.
Code:
#define FOSC                  20.0e6
#define DIA                   11.0
unsigned long rph = 0;
char msg[32];
char txt[32];
void interrupt() {
         TMR1IF_bit = 0;
         ++counter;
         CCP1IF_bit = 0;
         rps = rpm / 60;
         rph = rpm * (double)60;
        //1cm = 1e-5 km
         speedKmsPerHour = (double)rph * PI * DIA * cm_to_km;
         speedMilesPerHour = (double)rph * PI * DIA * cm_to_miles;
         //speedKmsPerHour = (double)rps * PI * DIA * cm_to_km * sec_to_hr;
         //speedMilesPerHour = (double)rps * PI * DIA * cm_to_miles * sec_to_hr;
         counter = 0;
    char *d;
    d = dest;
    return d;
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    UART1_Write(0xFF);
void main() {
    TRISC = 0x84;
    PORTC = 0x00;
    UART1_Init(115200);
    Delay_ms(100);
    T1CON = 0x31;
    TMR1H = 0x00;
    TMR1L = 0x00;
    TMR1IF_bit = 0;
    TMR1IE_bit = 1;
    CCP1CON = 0x04;
    CCP1IF_bit = 0;
    CCP1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    while(1) {
        LongToStr(rpm,txt);
        strcat(msg,txt);
        nextionWrite255();
        strcat(msg,txt);
        nextionWrite255();
        strcat(msg,txt);
        nextionWrite255();
        strcat(msg,txt);
        nextionWrite255();
        Delay_ms(1000);
MCU_1548107851
Joined Jan 21, 2019
30
i try all code it not working
you told me test without change any thing but i know problem from here
jayanthd
Joined Jul 4, 2015
945
Why problem ? Explain why ?
sprinti() does the same this as IntToStr() and LongToStr(). You just need to convert rpm, distance, etc,... values to string before sending to display.
Try this code. Don't change anything. I am getting in Proteus all the values.
Verify if these are correct.
360 pulses input per sec (Proteus test)
36 pulses per revolution
rps = 10
rpm = 600
rph = 600 * 60 = 36000
speed kms/hr = 36000 * PI * DIA * cm_to_km = 12.4407 kms/hr (verify if this is correct)
speed miles/hr = 36000 * PI * DIA * cm_to_miles = 7.7303 miles/hr (verify if this is correct)
Code:
//#define PROTEUS
#ifndef PROTEUS
  #define NEXTION
#endif
#define FOSC                  20.0e6
#define DIA                   11.0
char msg[32];
char txt[32];
void interrupt() {
         TMR1IF_bit = 0;
         ++counter;
         CCP1IF_bit = 0;
         rps = rpm / 60;
        //1cm = 1e-5 km
         counter = 0;
    char *d;
    d = dest;
    return d;
    UART1_Write(0xFF);
    UART1_Write(0xFF);
    UART1_Write(0xFF);
void main() {
    TRISC = 0x84;
    PORTC = 0x00;
    UART1_Init(115200);
    Delay_ms(100);
    T1CON = 0x31;
    TMR1H = 0x00;
    TMR1L = 0x00;
    TMR1IF_bit = 0;
    TMR1IE_bit = 1;
    CCP1CON = 0x04;
    CCP1IF_bit = 0;
    CCP1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    while(1) {
        #ifdef PROTEUS
          LongToStr(rps,txt);
          strcat(msg,txt);
          strcat(msg,"\r\n");
        #endif
        #ifdef PROTEUS
        #else
        #endif
        LongToStr(rpm,txt);
        Ltrim(txt);
        strcat(msg,txt);
        #ifdef NEXTION
          nextionWrite255();
        #endif
        #ifdef PROTEUS
        #else
        #endif
        Ltrim(txt);
        strcat(msg,txt);
        #ifdef PROTEUS
          strcat(msg," kms\r\n");
        #endif
        #ifdef NEXTION
          nextionWrite255();
        #endif
        #ifdef PROTEUS
          strcpy(msg,"speed = ");
        #else
        #endif
        Ltrim(txt);
        strcat(msg,txt);
        #ifdef PROTEUS
          strcat(msg," kms/hr\r\n");
        #endif
        #ifdef NEXTION
          nextionWrite255();
        #endif
        #ifdef PROTEUS
        #else
        #endif
        Ltrim(txt);
        strcat(msg,txt);
        #ifdef PROTEUS
          strcat(msg," miles/hr\r\n");
        #endif
        #ifdef NEXTION
          nextionWrite255();
        #endif
        Delay_ms(1000);
MCU_1548107851
Joined Jan 21, 2019
30
no its working !!!!!!
it should be like that
// LongToStr(rpm,msg); (((((((((((((( no need this line ))))))))))))))))
Ltrim(msg);
asm clrwdt
strcat(msg,"\r\n");
sprinti(envia,"n0.val=%d",rpm/1000);
UART1_Write_Text(envia);
UART1_Write(0XFF);
UART1_Write(0XFF);
UART1_Write(0XFF);
jayanthd
Joined Jul 4, 2015
945
Ltrim(msg);
asm clrwdt
strcat(msg,"\r\n");
UART1_Write(0XFF);
UART1_Write(0XFF);
UART1_Write(0XFF);
Why rpm/1000 while printing ? What is your min and max rpm's ?
Show video of working display for my final code with display drive code changed to yours. Don't vary rpm in video (don't vary variac voltage). Set rpm to 600 and send video.
See if these calculations are correct. According to my previous post.
rps = 10
rpm = 600
rps = 10
distance (cm) in 1 sec = rps * PI * DIA = 345.57 cm
distance (kms) in 1 sec = 345.57 * 1e-5 = 0.003455751915 kms
speed kms per sec = 0.003455751915 kms/sec
speed kms / hr = 0.003455751915 * 60 * 60 = 12.4407 kms/hr
speed miles per sec = 345.57 * cm_to_miles miles/sec
= 345.57 * 6.21371e-6 miles/sec
= 0.0021472717647 miles/sec
speed miles / hr = miles/sec * 60 * 60 = x miles/hr
speed miles / hr = 0.0021472717647 * 60 * 60 = 7.7302 miles/hr
spinnaker
Joined Oct 29, 2009
7,830
I don't ssee how this code can work:
What happens when the timer does not overflow before the CCP interrupt? counter will always be zero and the period zero.
