I am new to the electronics world. Built several small project and working my way up to building bigger projects.
So this will be a newbie question.
Needing to find a momentary switch that will control two separate circuits. When the switch is in the 'idle' state ( not pressed ) the switch closes circuit 1 and opens circuit 2. When momentary pressed, the opposite happens, circuit 1 is opened and circuit 2 is closed.
I could use 2 momentary switches to perform the task but that would be a poor design.
Thanks in advance.
JD
Thanks in advance.
JD
