help needed with servo motor
aliyesami
Joined Sep 12, 2009
24
I have never used a servo motor so please ignore anything stupid I ask.
I need to know if i can use a small dc servo motor to turn a lever from 0-135 deg and back to 0 ?
and what kind of drive signals are needed to step the motor at various angles ?
thanks
djsfantasi
Joined Apr 11, 2010
9,237
Yes, you can. Servos are driven with a PWM signal between 750-2250 Hz. 1500 is the center position. Google RC servo signals for details.
Actual positions are -90 to 90 degrees. Easily mapped to 0 to 180 degrees, which is inclusive of 0 to 135 degrees.
aliyesami
Joined Sep 12, 2009
24
thanks for the quick reply , i have experience with PWM signals so driving Servos should be easy.
any servo motor you can recommend to interface with ardiuno ?
aliyesami
Joined Sep 12, 2009
24
also wanted to ask , how fast the servo motor spindle moves ? I want a relative fast movement. , the PWM signal controls the angle so how do you conrol speed?
djsfantasi
Joined Apr 11, 2010
9,237
The speed is set by the parameters of the servo motor. You can drive it slower by stepping the angle and delaying between steps in software.
The Arduino natively supports hobby RC servos. There are sample sketches supplied with the IDE. The Arduino reference pages describe the servo library. You don’t directly write the PWM signal to the servo. You let the Arduino library do that.
28,332
OK, I am guesssing that it is not really an actual servo motor, but rather a Radio Control servo that must be used with a radio control receiver. That is a much different device.
SamR
Joined Mar 19, 2019
5,538
Yes, it is a hobby DC servo motor controlled by programming the uP in an Arduino. Usually comes with a bellcrank. Lot's of sources for them, Amazon, Alix, Digikey, and many others.
dendad
Joined Feb 20, 2016
4,641
No, they do not need a radio control receiver,
Just any device that can produce a suitable pulse train to drive them.
The Arduino is ideal as they are cheap and there is heaps of info on line of how to do it.
Reloadron
Joined Jan 15, 2015
7,949
thanks
Small hobby servo motors, like these as an example, use a PWM input as mentioned. The frequency should be at least 50 Hz because the servo motor wants a refresh rate about every 20 mSec, The pulse with will generally drive the motor 90 degrees left or right rotation and the pulse width is between 1.0 and 2.0 mSec. A pulse width of 1.5 mSec will place the rotor at center. They are easily driven by several means depending on exactly what you want.
Mentioned above and pretty important is choosing a servo which has enough torque to drive your load. Actually 0 to 135 degrees becomes -67.5 degrees to 67.5 degrees and yes, is very doable.
This would go better if your application in detail were known.
Ron
28,332
OK, but for the first 20 years they were ony used with RC receivers, and that is the format of the control signal. a variable width pulse every few milliseconds.
djsfantasi
Joined Apr 11, 2010
9,237
Well, for the last twenty years, that hasn’t been true. In fact, analog control of hobbyist RC servos is on the way out. Current RC servos are digitally controlled now. So your experience is at least two generations old.
shortbus
Joined Sep 30, 2009
10,049
You do know you're arguing with our newest "expert" don't you? He won't like that. :)
28,332
That is how they worked back in 1985, when investigated how they worked. And isn't the digital scheme still a pulse with signal? That is certainly digital. And why am I being called an expert? I don't think that I said that.
