Below is a schematic of a points assisted electronic ignition
what I would like to do is use a Hall sensor to replace the points
what I would like to know is a pull up resistor needed
the output of the Hall is 20mA is this enough to fully turn on the transistor
and what Tr would be best to use
do I need to add any other resistors anywhere
Hall sensor is a TLE4906LHALA1
as always thanks for your help
