Help needed with Boolean Algebra and DeMorgan
randb
Joined Dec 29, 2012
16
Demorgan problem
(( AB') (A'C))' One broke bar recd (AB')' + (A'C)'
then broke the bar again and recd A'+B+A+C' A'+a =1 1+ other variables =1?
Book states answer is (A+B') ( A'+C)
Where did I go wrong?
amilton542
Joined Nov 13, 2010
497
\( Y = [(AB')(A'C)]' \)
\( Y = (AB')' + (A'C)' \)
\( Y = (A'+B)(A+C') \)
Which is the same as you've got.
You're operating on expressions alone though, which is O.K, but could you type this "question" in it's entirety because something's missing.
jjw
Joined Dec 24, 2013
823
Last expression is missing + should be (A'+B)+(A+C')
33,192
Demorgan problem
Did you go wrong?
Let's check it out. You are claiming that the expression
((AB') (A'C))' = 1
This is of the form
(FG)' = 1
which is
FG = 0
F = AB'
G = A'C
If A is False, then F is False and FG is False.
If A' is False, the G is False and FG is False.
What does that tell you?
