help needed to read some C++ code
402DF855
Joined Feb 9, 2013
271
C:
template <typename R, typename... ArgTs>
class Callback<R(ArgTs...)> {
public:
  /** Create a Callback with a static function
  *  @param func  Static function to attach
  Callback(R(*func)(ArgTs...) = 0)
      if (!func) {
          memset(this, 0, sizeof(Callback));
      } else {
          generate(func);
I've not much experience with this type of template usage, but R is a type which "func" returns, and A0.... are parameters of the call to "func". Note that R is defined in the template declaration. The "=0" appears to specify that func==NULL if the callback is declared with no parameters, i.e. 0 is the default value for the parameter to the callback constructor.
bug13
Joined Feb 13, 2012
2,002
C:
public:
      if (!func) {
      } else {
          generate(func);
Thanks for the extra explanation, it really helps!!
BobaMosfet
Joined Jul 1, 2009
2,211
Function pointers in C are a lot more straightforward, than what you're looking at for C++. I mean seriously. A0-A4 are arguments, but they are _labeled_ to match assembly language registers (that's what they are likely referring to).
I strongly recommend you wrap your mind around these concepts in C before you jump to C++. It's easier. C++ is made for modeling (things like knee joints), it's not good for learning the things you're trying to learn because it expects you already know them.
bug13
Joined Feb 13, 2012
2,002
Again, thanks for your helpful advice. I do think I understand things like function pointer, pointer, address, stack and heap in C in a (bare metal and RTOS) embedded system, but most likely not as good as you.
For example, with the help of function pointer, I wrote this simple co-operative task scheduler that I use in most of my main powered application.
https://github.com/jmswu/schedular
However, for whatever reason, things are not always obvious for me when I first look at it. Often, a little pointer from someone like you and others with more experience can be a great help to me.
MrSoftware
Joined Oct 29, 2013
2,273
In a C function call, the stack is used to pass parameters. There's lots of good reading on it. If you're using a good IDE such as Microsoft Visual Studio, you can write a simple function call then turn on the disassembly window and step through the assembly as the function call occurs to see what's happening. Here's a google search that will lead to some good reading:
https://www.google.com/search?safe=...hUKEwjQ3sGb-rTkAhUGi6wKHeuWCOgQ4dUDCAs&uact=5
