help needed - tips and tricks to make the ground plane bigger
bug13
Joined Feb 13, 2012
2,002
Hi guys
I am testing an LoRa module from Microchip(RN2903):
http://ww1.microchip.com/downloads/en/DeviceDoc/50002390C.pdf
On page 12, it says:
The supporting board must be 84 mm long and 53 mm wide in order to generate that impedance and the average gain of 1.3 dB
But I can only allow for 64mm x 48 mm, is there any tips and tricks to make the ground plane bigger within these restriction?
Thanks guys!
PS: it also doesn't mention where to attache the antenna. On the long edge or short edge? Please let me know if anyone knows, cheers
AlbertHall
Joined Jun 4, 2014
12,663
It also says:
Modular certification of the RN2903 module is
performed with the PCB trace antenna as shown in
Figure 5-3. The exact dimensions of the trace antenna
must be followed.
