as Capacitance(C) of a material is given by AKE/d ,
how can the formula be given for Inductance (L) of a material ?
Neither capacitance nor inductance are properties of a material alone. The geometry is also a critical factor. In capacitence the geometry is parallel, conducting (usually metal) plates separated by a material with a dielectric constant. The dielectric constant affects the Electric Field between the two parallel plates.as Capacitance(C) of a material is given by AKE/d ,
