help me with connecting A ZVS to a flyback
liaifat85
Joined Sep 12, 2023
200
ZVS drivers can get hot under load. Attach a heatsink to the ZVS driver’s components (like the MOSFETs or transistors) for proper heat dissipation.
28,279
ZVS= Zero Voltage Switch, I guess. Those are frequently used for switching mains voltage, 120v or 220V, either50 or 60 Hz. Whatever voltage you hope to get out of a TV style flyback transformer will probably not be so very high as you are expecting, and then it will burn up.
A "flyback" transformer was made to operate at the TV horizontal sweep frequency, close to 15,734Hz for NTSC color displays, or 15,750 for monochrome displays.
