Need help with connecting external clock to D-Flip Flop
raziell122
Joined Mar 28, 2023
85
Hello everybody!
Wanted to ask please if it is common and possible to use Timer555 chip as an external clock generator for D-Flip Flop.
I checked the D-FF datasheet and saw that 'Buffered Clock' is written there but I couldn't find the meaning of it.
Thanks in advance for your help!
35,202
Hello everybody!
Yes. A 555-timer circuit output can be used as a CLOCK source. The supply voltage of the 555-timer should be the same as the rest of the circuit. Use a CMOS version of the 555-timer IC, such as LMC555, TLC555, ICM7555. Always insert a 100nF ceramic capacitor and a 10μF electrolytic capacitor across the power rails at the 555-timer IC.
raziell122
Joined Mar 28, 2023
85
Thank you!
Is LM555 ok? I must use devices from college's warehouse stock and I see in the components list LM555 and not LMC555.
35,202
LM555 draws higher currents from the supply rail. It puts excessive noise on to the rails. It is important that you place the 100nF and 10μF capacitors as close to the Vcc and GND pins of the LM555 IC.
38,855
The LM555 output high voltage is generate by a Darlington stage that, per the data sheet, goes to only 2.75V minimum with a 5V supply, which is marginal for many 5V logic families.
A 1kΩ resistor from the output to V+ will help pull the output up to near 5V with a low current (logic input) load.
Which logic family are you using for the flip-flop?
raziell122
Joined Mar 28, 2023
85
I'm going to use TTL 7474 D-FF
