Need help connecting a display
ai0ndra
Joined Mar 5, 2025
10
I have 4 Fixed voltage source and two Adjustable, and one voltage and Ammeter display someone knows how to connect it?, I just found videos of one power source. (I'm a beginner in electronics and sorry for any grammar mistakes
dl324
Joined Mar 30, 2015
18,476
What is the part number for the display? Do you have a manual/datasheet?
Do you want the meter to display information for all of the voltages? If that's the case, you need a way to switch the display between them.
28,395
If you purchased that meter from a distributor it should come with a single sheet showing which colored wire is for what. If you purchased it from amazon you are probably out of luck. Or if you lost the connection diagram.
One thing to be aware of is that many such digital meters require a separate ISOLATED power source for their operation.
ai0ndra
Joined Mar 5, 2025
10
Yeah I want the meter to display for all voltages. How can I make them switch?. Also I didn't find any kind of part number
ai0ndra
Joined Mar 5, 2025
10
It didn't come with any data sheet. Whit isolated... Cant just be the first thing that gains power?
dl324
Joined Mar 30, 2015
18,476
One way is to use a rotary switch. One with 4 poles and 5 throws would do it.
The way those meters usually measure current is by inserting a sense resistor and measuring the voltage drop across it. Multiple ranges would complicate things further.
These switches from Newark might do it, but they cost $56-166 and only one is good for more than 1A.
5 Position Rotary Switches | Newark Electronics
ai0ndra
Joined Mar 5, 2025
10
That's a really good idea sadly I can't buy anything and it's for tomorrow lol, but I thought of an idea what if I connect it this way, besides the aesthetic, does it work?, and if it doesn't why?
dl324
Joined Mar 30, 2015
18,476
I can hardly read that. if the yellow one is constantly changing of power source it shouldn't affect the meter right?
The devil is in the details. The info I posted was for a meter that required a supply of 4-30V. So as long as the voltage being measured was in that range, the second connection could be used.
For that particular meter, the red wire is the meter supply and yellow is the voltage being measured.
Without info for your meter, we have to guess.
dl324
Joined Mar 30, 2015
18,476
The banana jacks would have been more secure if you split them as indicated; and used a drill to make the holes.
ai0ndra
Joined Mar 5, 2025
10
Yes I think it's like that(the measure that I'm going to do is 5-12), the second connection means that I got to put both the red wire and the yellow wire in the Caiman?
28,395
Many of the cheap digital meters that I have seen require that the operating power supply for the meter be totally isolated from the voltages and currents connected for measurement.
So when the present meter fails, buy one that comes with the connection information.
