To solve this question all I know is I had to change the delta source to star shape (wye), then to find the current is using ohm law's with the voltage divided by the impedance which in the same line
I'm confused with this question, does the position of the source in delta and impedance matter?
I mean, can I just randomize the position of the voltage and impedance and got the right current?
thank you.
