Hello.
I'm an electronics newbie so forgive me for not knowing basic stuff.
I'm trying to understand how FSR potentiometers work for position and force detection. An FSLP is basically like a regular potentiometer but it detects pressure as well. They usually come in flat strips and you press on them along the strip and it can sense where you press along the strip and/or how hard you press.
It works like a regular potentiometer with three terminals where one terminal is a "wiper" and the other two have a fixed resistance track between them. The wiper will slide along the track and the resistance will vary between the wiper and the terminals based on the position of the wiper.
The FSR version is the same only the wiper has a resistance that gets smaller when you press harder.
There are different circuits for reading pressure or force as shown below.
What I don't understand is how it can accurately detect position when the "R-wiper" can vary between maybe 100kOhm and 500ohm or so depending on how hard you press. Shouldn't the voltage to the ADC_input on the left circuit vary a lot depending on the resistance of "R-wiper"?
Can someone explain how to calculate this?
