Help me identifying a connector
JMel
Joined Jun 20, 2024
3
Hello, I need help to know the name and suppliers of the connector shown in the image, this connector is soldered to an Ecopia SPCB-01 board and is used to hold a sample of semiconductive material and at the same time to inject a current or measure a voltage according to a Van Der Pauw test.
I need to do some testing but the price of the Ecopia SPCB-01 PCB is prohibitive so I want to create my own testing base.
panic mode
Joined Oct 10, 2011
5,210
what is the price? it seem to be 17500 Korean Won or about $12USD for board with clips. if that price is too high, you may want to make your own.
MisterBill2
Joined Jan 23, 2018
28,167
Certainly that brass part can be closely duplicated with common shop equipment, although the looks will not be as great. G10 glass PCB material and brass hardware and patience bending and cutting.
Probably silver plating after all the rest is done to assure a stable contact resistance will be a benefit.
