Hi LesJones,Hi Danko,
I don't undestand what all the added complexity achieves. You will only have about 1.75 uA flowing through the LED in the opto coupler (Assuming the LED has a forward voltage of 1.5 volts). You would get exactly result with just the 2M resistor in series with the LED. Also I don't think the opto coupler would work with only 1.75 uA current through the LED. The output side only needs a logic level mosfet to drive the relay.
Les.
Why? The TS merely wants to switch on a relay.After optocoupler we have series very short pulses
I hope, TS will demonstrate us how to do it. I can not do it better.Why? The TS merely wants to switch on a relay.
Terrific. In post #5, one was characterized at 70 µA. For the one that you found in ~30 s, what was the CTR at 100 µA? Was it enough to operate the relay? If so, then please don't keep it a secret, because that addresses the original question (irrespective of the additional and likely valid points that you raised).It took me about 30 seconds to find an optocoupler characterized at 100 µA.
That would later be Avago where things were arranged nicely. The data should be on the the Broadcom site well hidden after broadcom purchased them.Hewlett-Packard opto division published a lot or really good stuff on optocouplers many years ago. I would advise anyone interested in learning about optocouplers to scour the web for the HP stuff. Motorola also published quite a lot of useful ap notes on opto (and tons more on other things).
This?There was a very old HP opto ap handbook that faded to oblivion, probably because it also had a lot of stuff on 7-segment displays, but it had some good stuff that I never saw in later publications.
by Don Wilcher
by Jake Hertz
by Robert Keim
by Jake Hertz
