Hi Guys,
noob here.
- I have board A and board B. Both have MCUs.
- I have a reset signal going from board A to board B. The reset signal is normally HIGH (3.3V)
- I have a digital input signal (logic 3.3V) going from board B to board A.
- current implementation is two wires going to board A and B.
My problem is that, is there a way to implement it using only 1 wire?
The condition is that the reset signal should be independent of the state of the input signal because if the reset signal goes low, the whole system resets.
Is there a way to implement this by adding analog/digital circuits to board A or board B?
Thanks!
noob here.
Thanks!
