how can i compute the output secondary amps then, sorry im totally newSize E in that chart, 120VA.
Bob
Divide the VA by the voltagehow can i compute the output secondary amps then, sorry im totally new
Please measure the Primary DC resistance, and each secondary DC resistance, then post.hi again, my transformer weighs 1.25kg, its outer diameter is 94mm, height 39mm, inner diameter is 45mm.
Use an ordinary volt/ohm meter and measure the resistance of the windings (just like you would to measure a resistor)what you mean dc resistance?
Doesn't that look like a transformer symbol to you?hi! Please help me identify the current output of this toroidal transformer. There is no marking indicating how much amps on the output. The only marking is BX1201, the primary is 230VAC/50Hz, and secondary is 28Vx2-0-28Vx2, it has a 1.5A fuse in the primary. I got this transformer from a speaker with built-in amplifier. The speaker is MG Audio Box-1201 550W. I'm planning to use this transformer to build my own linear bench power supply, maybe 0-30VDC 5A if it can. I'm attaching the actual picture of the transformer below for reference. Thank you!
thank you, ludens. cl website is still alive and contents were very interesting! i dont know if its still updated but how can i reach the other? sorry o.tDoesn't that look like a transformer symbol to you?
Primary on the left, center-tapped secondaries on the right...
I've attached information on toroids. Don't know where I got that document from. Also, you might still find info at ludens.cl - if he's still around, he knows more about transformers, than anybody I've ever known. I learned from him- the man is brilliant.
Ok....this is likely a 120VA transformerprimary is 21.1 ohms,
between 28 and 0 is 0.6 ohms
between 28 and 28 is 1.3 ohms
In one post I provided an attachment- you should be able to click it and save it.thank you, ludens. cl website is still alive and contents were very interesting! i dont know if its still updated but how can i reach the other? sorry o.t
current out is a function of current in, in accordance with the transformer conversion between volts and amps as I previously mentioned-- and wire diameter. Smallest wire-diameter in line with NEC electrical codes determines max amps allowed without melting the lacquer on the transformer windings (which would make it short).thanks mate, again thank you very much to all of you, i really appreciate all your help. how many amps can i extract then if i use the two 28v, 56v in total? will it double or stay at 4A?
