[Help] Identify toroidal transformer output current
muno
Joined May 17, 2022
95
oh by the way, my transformer says 230VAC/50Hz, but my mains here is 230VAC/60Hz, what will be the effect?
sometimes our main doesnt even reach 230V, many time its lower, 216V
BobTPH
Joined Jun 5, 2013
11,665
No, that gives separate + and - supplies.
Why do you want to use 4 diodes when 2 is sufficient and gives you 1/2 the heat?
Bob
Ian0
Joined Aug 7, 2020
13,306
Nothing much should change. The transformer will run slightly cooler with no load as the peak flux will be lower.
dendad
Joined Feb 20, 2016
4,642
And you may be able to get a little more power out as the higher frequency is often a bit better core efficiency wise.
Ian0
Joined Aug 7, 2020
13,306
Yes, it works. Most people just use two diodes, especially when you can get a dual common-cathode Schottky diode.
muno
Joined May 17, 2022
95
i dont even know i cant use a dual diode like that as a bridge rectifier, thanks mate, anyway can i use even if its not a common cathode?
Ian0
Joined Aug 7, 2020
13,306
You could use it if it were common anode, (you would get a negative output) but not if it has two diodes in series.
muno
Joined May 17, 2022
95
hi , i recovered the mainboard of the speaker amplifier, and it has a bridge rectifier marking is fagor gbu8k. any hint on secondary current now?
