Help for Mplab
elefkokkonan
Joined May 28, 2007
2
I'm trying to programm a pic 16f877 using MPlab, though i've not been able to compile the simplest of progams. Even though there are no errors (only a few errors like 207 that are not of importance I think..) the assembling keeps failing... I keep seeing this message:
Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F877 "C:\Documents and Settings\Elef\Desktop\Arxh.asm" /l"Arxh.lst" /e"Arxh.err" /o"Arxh.o"
Warning[207] C:\DOCUMENTS AND SETTINGS\ELEF\DESKTOP\ARXH.ASM 5 : Found label after column 1. (STATUS)
Warning[207] C:\DOCUMENTS AND SETTINGS\ELEF\DESKTOP\ARXH.ASM 6 : Found label after column 1. (TRISA)
Warning[207] C:\DOCUMENTS AND SETTINGS\ELEF\DESKTOP\ARXH.ASM 7 : Found label after column 1. (PORTA)
Warning[207] C:\DOCUMENTS AND SETTINGS\ELEF\DESKTOP\ARXH.ASM 8 : Found label after column 1. (RP0)
Warning[207] C:\DOCUMENTS AND SETTINGS\ELEF\DESKTOP\ARXH.ASM 10 : Found label after column 1. (main)
Warning[207] C:\DOCUMENTS AND SETTINGS\ELEF\DESKTOP\ARXH.ASM 16 : Found label after column 1. (ARXH)
A language-plugin exception occurred and was logged.
BUILD FAILED: Mon May 28 13:44:30 2007
The programmm couldn't be any simpler...
LIST P=16F877
#include "P16F877.INC"
ERRORLEVEL -302
org 20h
STATUS EQU 03h
TRISA EQU 85h
PORTA EQU 05h
RP0 equ 5
main
bsf STATUS,RP0
movlw b'00000000'
movwf TRISA
BCF STATUS,RP0
ARXH: MOVLW 01h
MOVWF PORTA
MOVLW 00h
MOVWF PORTA
GOTO ARXH
END
Pliz I'm desparate i've tried everything:eek:
Dave
Joined Nov 17, 2003
6,969
yap mplab 7.60....
I think that is your problem. The only time I have seen this error is using v7.60 on code which works perfectly well with v7.52. Can I recommend that you try v7.52 instead of v7.60. I know others have experienced this problem using v7.60 and they fixed it by downgrading to v7.52.
Dave
Dave
Joined Nov 17, 2003
6,969
If mlab 7.60 is flawed, can one get the downgraded version free and if so, where? On the Mlab sight, 7.60 is offered
Its only flawed if you are experiencing problems like the one described in the OP. That said, the only way I know of downgrading is to use the original installation disc that MPLAB came on (if you have it) - I don't know of any (reputable) on-line sources for the download.
Dave
atferrari
Joined Jan 6, 2004
4,764
There is an option to download previous versions just there in the same place where you get the latest version.
Look carefully.
