Help! circuit simulation
declan2693
Joined Feb 2, 2018
37
Really need help. Could someone please simulate this circuit for me(on any simulator). I've tried 100's of times on PSIM but it doesnt work for some reason.
Here is the schematic. Ill upload my circuit also to show ive worked on it and not lazy. There is a problem with my switches. I've entered the correct duty cycle and such. The switch ive cycled wont turn on no matter what input voltage I put in it.
declan2693
Joined Feb 2, 2018
37
All I see is the number '1000000'. How does that indicate duty cycle, delay, on time, off time, cycle period etc?
Thats is the frequency. The duty cycle for V2 mosfet is 0.54. The duty cycle of the circled switch and the outputs is 0.46 with a phase delay of 194.4
38,503
Need to know the frequency, duty-cycle, and voltage swing of all the voltage sources controlling the MOSFETs.
And if there's a delay between signals give it in time, not degrees.
declan2693
Joined Feb 2, 2018
37
frequency is 1Mhz, duty cycle for V1,V6 switches is 0.54 so the other three are 0.46. The voltage input of all control sources is 1.5V. The mosfet threshold is 1V. Delay is 0.54/1Mhz
Marc Sugrue
Joined Jan 19, 2018
222
Another thing to note the NMOS FET shown in your schematic shows a reverse diode accross the Drain-Source which could be giving you a reverse path for your output caps to discharge (shown as negative volts on your waveforms i believe). The book circuit you attach treat the switch as hard on or hard off switches with no reverse potential.
ebp
Joined Feb 8, 2018
2,332
As Marc points out, the two right hand switches cannot be conventional MOSFETs, either N or P channel. These switches must be implemented using pairs of FETs - source to source or drain to drain
The circuit must operate in discontinuous inductor current mode or the boost and buck functions interact, getting current intended for the other side. Timing must be correct to avoid forced continuous mode at light load and to avoid disconnecting both ends of the inductor if it is not fully discharged.
The left FET must be ON continuously throughout the boost cycle, from the time the boost switch is turned on until the inductor is discharged.
There is a reason this circuit is not used. It is a very complicated way to do a poor job of something done much better otherwise.
declan2693
Joined Feb 2, 2018
37
Ok thanks for that. You say this circuit is not used. Do you have a better schematic for a single input dual output buck boost converter with four switches? I am trying to simulate something close to the TPS65135. I will keep at this.
Thanks to Marc also.
declan2693
Joined Feb 2, 2018
37
Hi guys,
I was talking to someone and they said I need to change from n-mosfet to p-mosfet for V2 and V6. Would that be correct?
ebp
Joined Feb 8, 2018
2,332
OK, I'm now confused as to the objective of the circuit.
Because of the name previously used, I took the intent to be to produce one output that is greater in voltage magnitude than the input and one that is less, both with the same sign as the input e.g. +10 V in, +5 V and +20 V out. The TPS65135 is intended to produce positive and negative outputs, which is something quite different. The inductor "is discharged to both of the outputs simultaneously...", so my previous remarks do no apply.
declan2693
Joined Feb 2, 2018
37
Hi, so basically I dont know how to do the schematic of the TPS65135 so I found the circuit show and trying to get that schematic I showed working before trying that
