need help, with simulation circuit
jacob13
Joined May 20, 2024
7
Green is the waveform of v1(input) and blue is the waveform for voltage across R2.
During the positive cycle (i.e when v1 is greater than 0v) diode will be short circuit and R2 is parallel to the short circuit branch it,s voltage will also be 0
but in this blue waveform the voltage is more than 0v(peak=2.4v)
Can anyone explain why it is 2.4v not 0v during positive cycle???
jacob13
Joined May 20, 2024
7
If you want an ideal diode add this line to your simulation:
.model idealDiode D(ron=0 roff=1G Vfwd=0)
and label your diode " idealDiode"
You're so helpful this cleared my mind but ive one more doubt why is that it is that in the practical waveform's peak value remains 2.4v.Does that mean the voltage remains constant across the diode (no more than 2.4v for 5v peak input)?? This doubt might be silly but i really wanna know what tspice did for its calculations.
35,131
Please use a thread title that provides some information on the nature of the thread.
"need help!!!!" is of no use to anyone.
Irving
Joined Jan 30, 2016
5,195
When the diode is non-conducting the output voltage is 0.5 x input, due to the voltage divider R1:R2, Vout = R2/(R1+R2) * Vin = 2.5v peak
Irving
Joined Jan 30, 2016
5,195
and when the diode is conducting , the output voltage is 2.3v peak(practically) because it remains constant at 2.3 peak because of input characteristics of the diode,right?
It will be whatever the forward voltage of the diode is at the current through the diode. Though the simulation is inaccurate because the diode is only rated for 300mA max, typically 100mA. If you changed the resistors to, say, 4k that would be a fairy accurate simulation.
