Help Calculating Moisture with with Analog Devices MCU and AD Eclipse IDE
Discussion in 'Embedded Systems and Microcontrollers' started by Ryan Jones, May 26, 2017.
  1. Ryan Jones
    Aug 27, 2016
    35
    Hey, all! Me again, from MIT-i, asking for help with programming.
    For our next video I am using an Analog Devices mcu, their version of the Eclipse IDE, and 0398 shield to measure moisture, specifically using this demo project.
    The catch is that I am using a different moisture sensor than what's listed in the project, shown here. Unfortunately, there is not much technical info in this datasheet.
    I need to convert the current moisture calculation to work with the new sensor. The github page with the source code is listed here
    The reason for the help is that I lack programming skill in C/C++ as I usually work with Arduino language or Python. Not asking for answers, but any insight helps!
    Thanks again, I love the help found within this community.
  2. shteii01
    Feb 19, 2010
    4,580
    725
    There is some work.
    Very little programming.
    Basically you don't want to do any of it.
  3. Ryan Jones
    Aug 27, 2016
    35
    As a basic hobbyist, I am not a programmer so extensive IDEs as such are confusing and overwhelming, especially when one small change effects 25 separate programming files, in an unfamiliar language. Recently, I've found a lot of support in this community, but I appreciate you at least giving it a look.
  4. shteii01
    Feb 19, 2010
    4,580
    725
    This is Arduino Uno level project. You said you can write code for Arduino.
  5. Ryan Jones
    Aug 27, 2016
    35
    My issue now is the IDE interface. After some code change and debugging, I decided to take a step back and run the original code as is just to see if I get a reading at all. Upon doing so I realized there is no, or I can't seem to locate, the serial monitor. None of the tutorials or user guides actually explain how/where to retrieve your data results. I've clicked through everything and googled for quite some time. Even if I had the proper sensor, working within the IDE is vastly different.
  6. shteii01
    Feb 19, 2010
    4,580
    725
    Use Serial Terminal program. Win7 does not come with one. There are several serial terminal programs that are quiet popular even within Arduino community.
