Help with calculating current
kazkaz
Joined Sep 6, 2023
In the answer model, they use Ohm's law to calculate I4, there they use V = Va - Vb, why exactly this order and not Vb - Va?
MrAl
Joined Jun 17, 2014
13,827
The simple way this is usually described is as follows.
The arrow is meant to show the flow of current using the CONVENTIONAL CURRENT FLOW concept in a two terminal device.
When that convention is employed, the terminal where the current ENTERS the device is said to have the most POSITIVE potential.
The terminal where the current EXITS the device is said to have the most NEGATIVE potential.
This can be summarized in a more memorable way:
ENTERS-POSTIVE
EXITS-NEGATIVE
This implies that to get the unsigned voltage across the device you would subtract the more negative potential from the more positive potential.
Example...
Top: 12v
Bottom: 5v
Voltage across: 12-5=7 volts
Example...
Top: 12v
Bottom: -5v
Voltage across: 12-(-5)=17 volts
BobTPH
Joined Jun 5, 2013
11,662
If you don’t like it, just reverse the arrow and use Vb - Va. And the answer will be negative instead of positive.
