hi Bertus, i understand you, i make one am radio receiver i had problem with antenna, so this dipole antenna can you tell me how to make wich diameter how does look, of some another antenna to connect, sorry i understand you dont like regenerative, i just need antenna, nothing more, how to make?Hello,
The strange thing is, that in the schematic they are talking about a dipole antenna, wich has two connections.
There is a single antenna connection drawn.
I am not a fan of regenerative receivers, as they can transmit a signal when adjusted wrong.
Bertus
Realy long wire with work, can you tell me please, how long the wire, big wire or small , wire, i am reading a litlle but some link dont open...Hello,
A dipole antenna for AM would be huge.
I think a long wire as antenna would already work.
See these pages of the EDUCYPEDIA for more information about the antenna types:
Antennas
Antenna list
Antenna types
Dipole antennas
Helical antennas
J Pole antennas
Loop antennas
Parabolic Dish Antenna
Radar technology
Yagi antennas
Bertus
thanks fHere is simplest long wire antenna you can do yourself using 10 AWG stranded copper wire.
http://www.winradio.com/home/ax05e.htm
And do not forget to ground your receiver.
https://www.ebay.com/itm/THHN-Brown-Stranded-Copper-Wire-10-AWG-100-Ft-/162972604711
I need to buy that thing and also too long wire.....i have ferrite rod, maybe somebody can help me with ferrit rod how to mame it, thank you anywayHere is simplest long wire antenna you can do yourself using 10 AWG stranded copper wire.
Hello, i have ferrit rod, if you have experience, can you told how to make it?AM band radios typically have ferrite loop antennas.
http://vaedrah.angelfire.com/antenna.htm
By the way lot of builders have experimented with regen radios,
google them, lots of designs and small forums devoted to regens.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=13&ved=0ahUKEwjRnc2d0ZfaAhXCpFkKHRWtDuQQFgh7MAw&url=https://pe2bz.philpem.me.uk/Comm/-%20ARRL/Build-Service-Design/Receivers/TheWBR-BetweenRegen+Direct/0108034.pdf&usg=AOvVaw3iuDllwK0HXsWjXtwWR2XM
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwjRnc2d0ZfaAhXCpFkKHRWtDuQQFgg1MAU&url=http://www.arrl.org/files/file/Technology/tis/info/pdf/9811qex026.pdf&usg=AOvVaw2ESzs0pbBMymYY6xdxZZy4
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&cad=rja&uact=8&ved=0ahUKEwjRnc2d0ZfaAhXCpFkKHRWtDuQQFghDMAY&url=http://www.arrl.org/files/file/Technology/tis/info/pdf/95hb1768.pdf&usg=AOvVaw2ihiJMl2D8nr902w6fczIV
Regards, Dana.
Thanks for time, is to long wire , i think better with ferrite rod ? its small, do you understand...The regenerative receivers I used to make (80 years ago) used, obviously, vacuum tubes and were nearly always for the AM band here in the US. The antenna was as long a length of wire as I could easily string up--sometimes only 3 meters, sometimes 30 meters. I used whatever wire I had, sometimes as small as 28 gauge, sometimes as thick as 16 gauge. Keep it as high off the ground as you can, though sometimes my antenna was only high enough to walk under.
Don't forget to use a ground. Here in the US a cold water pipe worked or any easily attached metal of your heating system (obviously not the power supply but the case or radiator or duct.)
Your circuit surprises me in a couple of ways. First is is stereo but it doesn't look like the receiver is stereo. Second are those half circles marked as X#--what are they?
Now what sound are you getting from the radio? A high pitched scream usually means too much regeneration. How does this circuit adjust the amount of regeneration? If it isn't screaming at you, do you hear anything? Does it change as you tune across the band? What frequency are you hoping to hear?
This is a lousy circuit, what frequency band do you want to use?he
hi, can somebody help how to build one easy antenna for this circuit, i thougt you just take one 5, 6cm wire and you receive signal(but that was not true), i did not know so difficult like i search in google, i see some big antenna here is the circuits, just anntena problem to make
Energy of electromagnetic wave spread in space volume.I need to buy that thing and also too long wire.....i have ferrite rod, maybe somebody can help me with ferrit rod how to mame it, thank you anyway
My dad told me about building radios when he was a kid in the 1930's. He would string a wire between the house and the barn or other outbuilding. He said that when the wind blew the wire would collect enough static charge that he could draw a spark from it.The regenerative receivers I used to make (80 years ago) used, obviously, vacuum tubes and were nearly always for the AM band here in the US. The antenna was as long a length of wire as I could easily string up--sometimes only 3 meters, sometimes 30 meters. I used whatever wire I had, sometimes as small as 28 gauge, sometimes as thick as 16 gauge. Keep it as high off the ground as you can, though sometimes my antenna was only high enough to walk under.
Where do you see this?Band of your receiver is about 400kHz...3MHz.
F = 1/[2pi√(LC)]In #1 schematic inductance L1 = 1uH, capacitance VC1 accept 3pF, then reactances L1 and VC1 will equal on frequency 3 MHz..
For 1uH and 160pF reactances will equal on frequency 400kHz.
I read long time ago NavoEnergy of electromagnetic wave spread in space volume.
Therefore, than bigger antenna, then more energy it collects from wave in space.
Receiver + long wire antenna will up to 1000 times more sensitive, than receiver + ferrite rod antenna.
Especially in shortwave band.
Edit:
12.582 MHz ... 91.888 MHz (Thanks to Ylli)
Long wire and ferrite rod antennas:
https://www.wikihow.com/Wind-an-Aerial-for-Am-Radio
In attachment:
"Antennas and Wave Propagation" US NAVY book.
