Hello, I need help with a 0 to 33 V reversing power supply.
bot?123
Joined May 1, 2025
Hola el problema es que mi transformador es de entrada de 127v a 60 hz y salida de 33v a 1.2 Aquie el detalle es que quiero meter un multimetro amperimetro y un fusible americano boton de apagado potenciometro cable de alimentacion c14 con su clavija pero estado consultando varios diseños pero no todos tienen partes es como un frankestein asi que alguien podria ayudarme ?¡
Mod:translated. Use English text.
Hello, the problem is that my transformer has an input of 127v at 60 Hz and an output of 33v at 1.2. The detail here is that I want to put in a multimeter, ammeter, and an American fuse, a power button, a potentiometer, and a C14 power cable with its plug, but I have been consulting several designs, but not all of them have parts, it is like a Frankenstein, so could someone help me?
dl324
Joined Mar 30, 2015
18,490
This is an English language site.
38,909
What exactly are your current requirements for the 0-33V supply output?
Do you want DC?
What do you mean "reversing"?
schmitt trigger
Joined Jul 12, 2010
2,273
I can read directly from the original Spanish, and although the description is not clear at all, I can gather that the TS has a “transformer” which is feeding from the AC line, and wants to add a fuse, an on/off switch, a pot presumably to adjust the voltage, and an ammeter/voltmeter.
He has seen some web schematics but really doesn’t understand them.
No mention of polarity reversal other than the thread title.
In plain English, he wants a variable power supply with output metering. Presumably DC.
28,485
A more detailed description is needed before much of an correct response can be given.
A good guess is that the TS wants a variable voltage power supply, adjustable over some voltage range, with voltage and current meters. The "C14 power cable" meaning is unknown to me.
MY GUESS is also that the circuits the TS has discovered do not include parts lists, but only circuits. THAT is very common at those websites that provide circuit information only. "Schematics For Free" is a very good site but indeed mostly does not provide parts lists.
