Heatsink for Bridge Rectifiers D25XB60
abuhafss
Joined Aug 17, 2010
318
I need to use two bridge rectifiers D25XB60 in a project, which are to be attached to a heatsink. The problem is that I do not have enough space to accommodate both of them side by side. I am considering to install one unit over the other as shown in the diagram. Which of these approaches be more better?
Shall highly appreciate valued comments.
alfacliff
Joined Dec 13, 2013
2,458
the metal on the back of the case muxt contact the heatsink. how can you do that when stacking two packages? the thermal resistance for the top one will be high.
22,084
Since they are thru hole components you should mount them vertically. This has the advantage of adding convection to the cooling mechanism.
22,084
With components like this one and 3 dimensions to work in there is no reason why they have to be bent over to attach to the heatsink. Why can't they be attached to a heatsink that does not even touch the board. Give us a mechanical drawing of the board and heatsink.
34,837
Neither approaches is a good idea.
You want each device to be in contact with the heat sink.
Then you need to double the size of the heat sink.
abuhafss
Joined Aug 17, 2010
318
Actually, these are to be enclosed in an aluminum housing which will also act as heatsink.
The final position would be something like this:
B/Rectifiers attached at the bottom with pins pulled up and soldered on the PCB.
And the whole set-up would be sealed in that aluminum housing using epoxy glue.
abuhafss
Joined Aug 17, 2010
318
So, I think there is no solution. I should make adjustments in the PCB.
Another related question please:
The same project include TO-220 devices which also require heatsink. I shall be using common heatsink with mica insulator and h/s paste. Where the h/s paste should be applied?
a) between the heatsink and the mica insulator
b) between the device and the mica insulator
c) or both
