Heating coil based on bluetooth input
Siddharth Mehrotra
Joined Jul 15, 2019
11
I want to heat coil based on the input value received by bluetooth device.
I made a small circuit also for this. I am using Kanthal wire for heating, it's 22g wire which is 1.31Ω per foot. The wire needs current of 2.5 amp with 3.7 V battery to heat.
I am transferring ASCII values to bluetooth device with my phone.
Here is the code I am using:
Code:
char c;
int state = 0;
uint32_t period = 1 * 60000L;//  1 min
   void setup() {
    while (!Serial);
     Serial.begin(9600);
     Serial1.begin(9600);
   void loop() {
    if(Serial1.available()){
    c = Serial1.read();
    Serial.println(c);
    if(c=='7'){
      for( uint32_t tStart = millis();  (millis()-tStart) < period;  ){
   digitalWrite(A7, HIGH);
delay(1000);
The bluetooth is working fine! Example: When I send a ASCII value 5, I can see on Arduino serial monitor 5.
The problem is the circuit! I am not able to understand where I am making the mistake as based on the bluetooth input, fire is not heating up. Please help.
BobTPH
Joined Jun 5, 2013
11,656
Multiple things wrong with that code.
You say you are sending a '5' and the code is only doing anything if it sees a '7'.
What the code does is wrong. It keeps setting the output high in a loop. No line ever sets if off, so, if it worked, the wire would stay heating forever.
Line up the { and } in the code so we can more easily see what code is contained within each structured statement.
Bob
Siddharth Mehrotra
Joined Jul 15, 2019
11
Bob
Actually 5 is just example of value I am sending! Even if I send 7 nothing happens according to my circuit. Also, I understand that I didn't turned off the heating, but that's not the issue. The problem is with the circuit design I have the above code doesn't heat the coil. (See the Fritzig Diagram)
dendad
Joined Feb 20, 2016
4,641
Your breadboard layout leaves a lot to be desired. But that aside, where is the power to the boards?
Have you written a test to just pulse the output on and off, not using the bluetooth?
Test that you can drive the heater first. Add an LED with resistor so you can see it switching.
oz93666
Joined Sep 7, 2010
742
At a guess you have too much resistance in the (heating) circuit ...
You have very low voltage and want high current so you cannot have even modest resistance in connecting wires , contacts , and resistance in components ..
Stepping up the voltage must be the answer , within the limits of the circuit.
Siddharth Mehrotra
Joined Jul 15, 2019
11
The FLORA is powered by USB from computer & coil by battery as it requires high current to heat up.
I will test with LED and update you! Thanks.
Siddharth Mehrotra
Joined Jul 15, 2019
11
I am using a separate battery to power the coil as it requires high current. I will reduce the resistance and will update on that. Thanks.
djsfantasi
Joined Apr 11, 2010
9,237
Doesn’t the Bluetooth TX pin need to be connected to the Arduino/Flora RX pin?
As shown, nothing will ever received by the μp, and hence the digitalWrite() will never be executed. Hence, no current will flow to the wire; no heating will occur.
Plus, if the μp is a 5V device, it’s TX pin must be reduced so that the Bluetooth module isn’t damaged.
Picbuster
Joined Dec 2, 2013
1,062
Code:
char c;
int state = 0;
   void setup() {
    while (!Serial);
     Serial.begin(9600);
   void loop() {
    c = Serial1.read();
    Serial.println(c);
    if(c=='7'){
delay(1000);
I am missing parts of program like millis()
and the vars named tStart and period;
Advice:
use pwm assuming 0-9 input producing 0-100% pwm signal.
It will help if you put components in your schematics in a more logical position (+ connections up and inputs one side outputs at the other). Doing so makes schematics easy to read.
Please don't see this as a negative remark but to help you.
Picbuster
