Heater for Petri dish
Kadav
Joined May 11, 2018
158
Hello i have to heat a petri dish for some appliances , and i would love to know which recomandations of heater can you please give me ?
It is for small samples .
thanks
Kadav
Joined May 11, 2018
158
A lot of specifics are unanswered, like size of plate, open or closed, uniformity of temperature needed, temperature range.
For starters, I would use a temperature-regulated hot plate. Surely, the arduino crowd has something like that virtually plug and play. You could also use a heating pad like the round one here: https://www.omega.com/en-us/industr...VR9bACh0_6wGTEAYYAyABEgJjmvD_BwE&gclsrc=aw.ds
Minco is another supplier.
Thank you very much , the plate is opened and the size of 90 mm and i need to keep on temperature of37 deg
jpanhalt
Joined Jan 18, 2008
11,087
My advice is the same. You will not need much wattage. If the temperature must be stable across the plate, I would lean toward using a hot plate or aluminum disk slightly larger. The disk could have a machined depression to hold the plate more securely.
Kadav
Joined May 11, 2018
158
And how could you plug the plate to the arduino , i understand the use of the silicon mat, but not the hot plate . or it is the same ?
jpanhalt
Joined Jan 18, 2008
11,087
You will not be able to connect the heating pad or hot plate directly to the arduino. Or, while you may be able to connect it, I don't think it will work.
Your arduino is the controller. It can read a temperature from an appropriate sensor. Almost any sensor will work for that temperature range. Then it can provide a control signal to the heater power supply to keep a constant temperature.
Kadav
Joined May 11, 2018
158
Oooh alright , i understand , my idea was basically to drive the heater with a MOSFET that is connected to an arduino . that probably would give 12volts . but i have never pluged a power supply to arduino .
do you know any power supplies that go to arduino ?
Thanks for the help
ElectricSpidey
Joined Dec 2, 2017
3,375
You might be able to make use of a 1500 watt 120 volt stove element, running at 5 or 12 volts.
12 volts should give you about 15 watts and 5 volts should give you about 3 watts.
Then you could just use your MOSFET and drive the element.
There are companies that make low voltage heater elements.
Kadav
Joined May 11, 2018
158
you mean as a heater?
