I was wondering if they make heat sinks for lm386. This amp has 8 pins and I am looking for something that has similar dimensions to absorb the heat.
I am building a amplifier/oscillator and I am using a lm386 and a 555 timer for my circuit.
I have built this circuit in the past and I have used a 0.25 mA fuse for protection. I was also wondering if there is a circuit breaker which toggles. Most of the cicuit breakers have a factor of.. hence (1 amp times 3 = 3 amps). I want to build a circuit that has a total of (333mA times 3 = 1 amp). Does a 333mA cicuit exist or something similar. I am trying to avoid using fuses and wish to use a circuit breaker that will work with the values mentioned.
