heat sink part number identification
ak52
Joined Oct 15, 2014
241
I am looking for heat sinks like that online but i am not able to find any,is there any standard size or form factor which i could use as a reference?
ErnieM
Joined Apr 24, 2011
8,415
paulktreg has a good point. This is not a purchased heatsink but something the manufacturer made from a standard aluminum extrusion.
There is no reason it must look like your picture, you may want a different (simpler) shape to move heat from one place to another.
ak52
Joined Oct 15, 2014
241
I see ,thanks guys,i was under the impression it was a standard part.Any aluminum piece would do the trick in this case
12,161
That probably is a chunk of aluminum angle cut to length and drilled. Lowes, Home Depot, etc. It is an extrusion, not a bent piece. It might be a custom extrusion, but it is not a catalog standard heatsink part. Note the two solderable legs crimped on. This used to be a sign that the part was from a heatsink company, but I've seen CMS shops bring this technique in-house.
