Headphone wire detached: Where should I connect these red and white wires?
Rohane4567
Joined Oct 28, 2024
help my headphone wires de attatched and the l l+ labels already have some small wires attatched i don see any other labelsIMG_20241028_120443.jpgIMG_20241028_120549.jpgIMG_20241028_120500.jpg
35,249
L+ and L- is for the left channel.
R+ and R- is for the right channel.
It doesn’t matter much if the connections are reversed because the left and right headphones don’t interfere with each other.
ericgibbs
Joined Jan 29, 2010
21,610
Hi Rohane,
It is important that the Red and White wires are connected to the correct earphone terminal.
You should have the Left and Right ears being driven in phase with the audio signal.
eg: both sending the air compression and air rarefaction signals to the ears in phase
E
