Bordodynov
- Joined May 20, 2015
- 3,433
startup sets the zero value of the voltage to voltage sources at zero time and after 10 μs these voltages will take their meaning.UIC allows you to set the initial value of the voltage on the capacitor, for example C11 4 0 100u ic = 20.For inductance, you can specify a current, for example L6 3 4 100mA ic = -100mA.You can also specify a voltage in any node of the circuit, for example .ic V (7) = 3 v (2) = - 1. Thus, one can not wait until the stabilizer (or rectifier) charges the output capacitors (i.e., reduce the time that the circuit enters the stationary mode). It can also help improve the convergence of the calculation.
