Looks like about #4 AWGHow thick are the cables on the starter motor?
Sometimes, when the battery is low, the starter solenoid fails to release and the starter motor cranks until the battery is dead. The solenoid being mechanically stuck, you have to kill the main supply to stop the failure mode. Still haven't decided...big old switch on the battery or a fuse.Why do you think you need a fuse??
That is true. Unfortunately, replacing the solenoid only gets me the same solenoid.Sounds to me the solenoid is not working properly.
This cable isn't designed as a continuous current wire. It's designed for x number of volts of loss at y number of amps. Standard building codes do not apply to this design. The length being about 14 inches.#4 AWG Can carry around 70-80A. So it should be somewhere around those numbers when under heavy load.
and the battery in my car is rated for 450 CCA, but that never happens.The typical battery for a Harley is rated at 200 to 270 CCA. (Same battery size as a 1500 Honda Goldwing.)
......and how would a fuse solve this problem??...................This isn't a problem on one motorcycle, it's a design flaw in the solenoids.................
Still haven't decided. Maybe a long duration current compared to the usual 1-2 seconds of cranking.......and how would a fuse solve this problem??
LOLZ.I'm going with the ~100 amp estimate as well. It's about what my 22 HP B&S engine on my lawn mower draws.
A two cylinder Harley and two cylinder B&S are about the same right?
Harley's always start the first time......... A fuse would just contribute to a different kind of problem.Still haven't decided. Maybe a long duration current compared to the usual 1-2 seconds of cranking.
