can't argue with that...You are both wrong, it is the moment when the cap comes off of the Cumin bottle that things gets nasty.
Meanwhile, in a random newspaper correction...View attachment 101562 how DARE you speak evil about cilantro!!!! One just can't have a decent, true-to-its-spirit mexican "pico de gallo" salsa without it!
It's parsley that ruins most things it touches instead!
Some would disagree with that "correction".
Don't blame them. They can't help it.
http://eatdrinkbetter.com/2015/02/13/cilantro-tastes-like-soap/
A reporter with at least half a brain would have written that correctly...There’s a scientific reason for all that loathing: 10% of the population was born with a genetic defect variant. Researchers looked at the genetics of about 14,000 people and found a DNA variation believed to be the root cause of the soapy smell and taste some people associate with cilantro.
There’s a scientific reason for all that loathing: 10% of the population was born witha genetic defect varianttastebuds. Researchers looked at the genetics of about 14,000 people and found a DNA variation believed to be the root cause of the soapy smell and taste some people associate with cilantro.
Maybe once - I've had a solenoid weld its contacts, but if the main switch releases yours, it isn't that.Looks like about #4 AWG
Sometimes, when the battery is low, the starter solenoid fails to release and the starter motor cranks until the battery is dead. The solenoid being mechanically stuck, you have to kill the main supply to stop the failure mode. Still haven't decided...big old switch on the battery or a fuse.
Starter solenoid out of a Ford with a panic button.
Yes.Does the OEM solenoid also engage the starter gear?
Is that why you can't get rid of it?
Let's just say it's widely used in menudoIf I knew what cilantro is, I would know whether I agree.
Menudo? You mean the band??Let's just say it's widely used in menudo
Where I live, cilantro is used to refer to the leafy greens of the plant. Coriander refers to the seed mostly, or the root. So dry coriander is not dried leaves, it's ground seeds. Same plant.Cilantro is what you yanks call Coriander!!
I guess I could wire the harness provided, to ground both the spark coils (7 amps), and see if the engine stops before the 5 amp insulation melts.Your kill switch applies voltage to a relay to activate the kill function. Shouldn't the kill switch remove a voltage to activate the kill function?? I know some bikers that use the kill switch as an on/off switch.
The starter motor does not keep the gasoline engine running when there is no spark, so I think I can allow that to continue functioning. If the customer is arriving at his garage, hits the kill switch, and presses the starter button at the same time, I will have to find a way to disable the starter when activating the kill switch.shouldn't the kill switch disable the starter??
Most of the old bikes I had; the kill switch was just a switch that breaks the 12V feed to the ignition coil.Your kill switch applies voltage to a relay to activate the kill function. Shouldn't the kill switch remove a voltage to activate the kill function?? I know some bikers that use the kill switch as an on/off switch.
Also, shouldn't the kill switch disable the starter??
by Jake Hertz
by Duane Benson
by Don Wilcher
by Duane Benson
